Little Dot LD-Y1 Balanced Tube Headphone/Speaker Amplifier
Current production Little Dot models and pricing
Features:
  • Split structure
  • Tube rectifier
  • Power tube: jj300b x 2
  • Driver tube: 6sl7
  • Rectifier tube: 5u4g x 2
  • Permalloy input transformer
  • High quality silicon steel sheet output transformer
  • Mundorf capacitor
  • Kiwame HiFi resistance
Technical Specifications:
  • Input:
    • XLR balanced input x2
    • RCA unbalanced input x2
  • Headphone output:
    • XLR (4-pin) X1 (balanced headphone output)
    • 6.35 (3-pin) X1 (unbalanced headphone output)
  • Speaker output terminal: 4 left and right channels
  • Distortion: 0.1% (1000Hz)
  • SNR: 98dB
  • Frequency response:
    • 20Hz - 20KHz (-0.2dB)
    • 10Hz - 50KHz (-2dB)
  • Output power:
    • 10W (8 ohm)
    • 6W (120 ohm)
    • 3W (300 ohm)
  • Magnification:
    • GAIN=HIGH: 7
    • GAIN=LOW: 4
  • Power consumption: 150 VA
  • Size: 350x210x220 (H) mm
  • Weight: 23 kg (include the power supply, package and accessories)
