Little Dot MK VI+ Balanced Headphone Amplifier
Current production Little Dot models and pricing
The Little Dot MK VI+ is a fully balanced architecture, the Little Dot MK VI+ has exceptional dynamic range and can produce clean amplitudes of 70Vp-p into 120 ohms! The balanced Class-A SEPP (single-ended push pull) OCL (output capacitor-less) circuit topology delivers rich tonality and brute force clean power for maximum dynamics and low frequency impact. We carefully selected quality components to make up the Little Dot MK VI+ circuit, and you will find Neutrik, ALPS, Vishay-Dale, WIMA, ERO, and CHEMI-COM among the critical circuit components used. The Little Dot MK VI+ also adds in user-tweaking options such as two gain settings to delivery maximum compatibility with your headphones!
See what people are saying about the Little Dot MK VI / VI+:
Little Dot MK VI Review @ Head-Fi
Technical Specifications
  • Available in either Black (default) or Silver
  • Fully Balanced Architecture
  • SEPP (Single-ended Push Pull) OCL (Output CapacitorLess) in Class-A
  • Active 2 fan cooling
  • Driver Tubes: 2x 6H9C
  • Power Tubes: 4x RCA 6080
  • Inputs:
  • Balanced: 2x 3-pin XLR
  • Single-ended: 2x RCA
  • Outputs:
  • Balanced: 4-Pin XLR
  • Balanced Pre-Amp: 2x 3-pin XLR
  • Single-ended: 1/4" (6.35mm) TRS Stereo jack
  • Frequency Response:
    • 5Hz - 80KHz (-3dB)
    • 10Hz - 30KHz (-1dB)
  • Input Impedance: 50K ohms
  • Pre-Amplifier Output Impedance: 600 ohms
  • THD+N:
    • 0.02% (2Vrms @ 1000Hz)
    • 0.06% (10Vrms @ 1000Hz)
    • 0.3% (20Vrms @ 1000Hz)
  • Signal-to-Noise: 92 dB
  • User Selectable Gain Settings: Low (10 dB) and High (15 dB)
  • Power Output:
  • 1W per channel into 50 ohms, 5W per channel in 120 ohms
  • Power Consumption: 25 VA
  • Measurements:
  • Metric: 350mm (length) by 290mm (width) by 140mm (height)
  • Imperial: 13.8 inches (length) by 11.4 inches (width) by 5.5 inches (height)
  • Weight: 9.6 kg or 21 lbs
  • Available in either 110-120VAC or 220-240VAC
  • One Year Official Little Dot Warranty
