Little Dot LD 3 SE adopts the most famous German Telefunken™ EL152 as the power output tube, and the driver stage adopts American Western Electric™ WE408A. These tubes are now legendary "artifact", we only have 150 sets of new NOS stock, so this amp. is worthy of the name of "Limited Edition".
The output transformer is specially designed with Z11 silicon lamination, coupling capacitor is German silver foil oil immersed capacitor, resistor adopts KIWAME for audio, internal wires are all Teflon silver, even the soldering also adopts German silver containing solder. The headphone output part adopts the technology of "impedance intelligent recognition" developed by ourselves, which can automatically detect the impedance of the headset and convert it to the corresponding interface.
The EL152 has a strong output power (larger than the famous 300B); its sound quality is exquisite and has more musical details!
The input port
- RCA x2
The output port
- 6.35mm X1 (headphone output)
- RCA x2 for pre amp. use
Technical Specifications
- Input impedance:10K Ω
- Distortio: 0.1% (1000Hz )
- SNR:96dB
- Frequency response:20Hz - 20KHz (-1dB) / 20Hz - 40KHz (-2dB)
- Output power:
10W @ 8Ω
6W @ 32Ω
2W @300Ω - Adapter headphone impedance:32Ω-600Ω
- Magnification:
Gain = HIGH:10
Gain = LOW:5 - The power consumption:120 VA
- Size:230x250x140 (H) mm
- Weight:8 Kg (including the power adapter)
