Little Dot MK III SE is a hybrid and fully balanced amplifier, you can think of it as the ultimate upgrade for MK III series.It uses 6N11 as its preamp tubes(6922/ECC88,etc.) Transistor part runs on a fully discrete, fully symmetry, and pure class A circuit design. The amp is balanced and it has 3 pin XLR balanced input and 4-pin XLR output, and it also has a RCA input, 6.35 output. Very delicate two layer oxidation on chassis, and a gold-plated tube rack.
The input terminals
- Balance: XLR 3 pins x2
- Ubalance: RCA x2
The output terminal
- Balance: XLR 4 pins x1
- Ubalance: 6.35 mm x1
Technical Specifications
- Input impedance:10K Ω
- Distortion degree:0.001%(1000 Hz)(output: 2v RMS)
- SNR:95dB
- Frequency response:5 hz-100 KHZ(1 dB)
- Output power:
2.5W (32 Ω)
1.8W (120 Ω)
0.8W (300 Ω) - Adapter headphone impedance:32 Ω-600 Ω
- Magnification:
Gain = HIGH:9
Gain = LOW:4.5 - The power consumption:30 VA
