Hi,
I've been taking a look and I'm thinking about buying a MKIII or MKIV.
I'm interested in any experiences with Sony MDR7520 (or similr) headphones. I'm concerned because their impedance is 24 Ohms and don't know how this will work with the amplifier unit.
Any input is much welcome.
Thanks so much in advance and best regards,
Aitor
Sony MDR7520
Re: Sony MDR7520
Both the MK III and MK IV would have no issue driving your MDR7520 however I would recommend using the 5x or 10x gain setting for the best results. You may also want to consider the Little Dot I+ as it's specifically designed to drive low impedance headphones and thus will offer better performance at a lower price point.
Re: Sony MDR7520
Thanks for the input.
Much appreciated
Best,
Aitor
Much appreciated
Best,
Aitor
