hello, some how my last post was gone.
Anyways,
I plan to get a Littledot amp for my headphones.
Source is ps3 for movies or iphone airplay to Marantz SR6009 receiver for songs.
For movies, it might just go straight to Emotiva DC-1 Preamp.
Headphones wise, I got an AKG K7xx. And I also have Sennheiser HD 800 on the way.
Please recommend a little dot. Thanks
Little Dot for HD 800 and AKG K7xx
Re: Little Dot for HD 800 and AKG K7xx
For both your K7xxa and HD800, I would recommend the MK III at minimum and the MK 6+ as the top-end option (especially if you go balanced). The Little Dot I+ is a good option for the AKGs, but you'll need the OTL design of the MK III to take full advantage of the HD800's performance.
get the MkIV se!
