Hi! I am thinking about using my Little Dot in the next set:
IMac - Cambridge Audio DacMagic 100 - Little Dot MKIII - Onkyo TX-SV454 - Monitor Audio BX 2
Is it right?
Little Dot MKIII as a preamp
Re: Little Dot MKIII as a preamp
Yes, that is a valid setup if you want to use the MK III as a pre-amp for your speaker system.
