Which power amp to use with my LDmk3
Discuss headphones, speakers, subwoofers, etc!
uglyjoe0124
Post by uglyjoe0124 »
Hi there
Ive just purchased a 2TB music server which im loving through my dacmagic and then in to my LD MK3 with my headphones.
The question is which amp do I get as I will be using my LD as a preamp.it would be nice to listen to speakers for change.
Does any body out there have or use a tried and tested set up
Re: Which power amp to use with my LDmk3
uglyjoe0124 wrote:Hi there
I would recommend deciding on a power based on it's own merits since the MK III will work well with anything that's AC coupled. Just make sure the power amp is not DC/direct coupled and you are good to go.
