little dot I+
Talk about anything!
b.timofte
little dot I+
Post by b.timofte »
I have bought this hybrid amplifier.
I connect the output of my Fiio E17 DAC and amplifier to the Little Dot I+.
I use HD 650 headphones.
The problem is when I turn on the DAC and then the AMP I hear a loud pop in my headphones L+R... I am worried about this , so I decided to plug the headphones 1 minute after I turned on the AMP ...Will this damage the AMP ?
Re: little dot I+
You can plug in the headphones at anytime, however you should not be getting any kind of loud pop.
