MK III impedance
badgordo
MK III impedance
Post by badgordo »
Can I use a Shure SE215 on MK III (Impedance @ 20 Ω)? Which gain setting should be used? Thanks!!
Re: MK III impedance
Most IEMs are optimized for use from a portable player and thus don't really benefit from beefy amplification. That said, if you want to add a touch of tube warmth and tonal richness to your sound, you can use the Little Dot MK III and the lowest gain (3x) is more than enough.
