Recommendation for LD Tube Amp
f3lixioz
Post by f3lixioz »
Hi all,
I currently own a Beyerdynamic T-90 (250 ohms) and a TianYun Zero 627U DAC. I'm currently between the LD 1+ and Mk.II; which of these (or if you have any other recommendations) would you suggest for my setup?
fluidusmisticus
Re: Recommendation for LD Tube Amp
Post by fluidusmisticus »
f3lixioz wrote:Hi all,
Hi. The LD 1+ is an amplifier mainly for low impedance dynamic headphones. I don't believe that LD I+ has the power for a Beyerdynamic T-90. Instead, LD Mk II is probably a good amp for a 250 ohms' impedance.
The LD Mk IV SE should be even better...
