Doubt on MK VIII SE
fluidusmisticus
Doubt on MK VIII SE
Post by fluidusmisticus »
Hello Everybody. I have a question: Is normal that pre-amp 12at7 tubes on mk viii se are less "bright" (much less intense brightness) when they working, than power tubes 6h30pi?
Re: Doubt on MK VIII SE
Yes, the tube brightness will be model/version dependent and does not have impact on the sound or performance. Only if the tube begins to shine a purplish color (which means it's about to go out) do you need to take action.
fluidusmisticus
DavidZheZhe wrote:Yes, the tube brightness will be model/version dependent and does not have impact on the sound or performance. Only if the tube begins to shine a purplish color (which means it's about to go out) do you need to take action.
Thank you for the clarification.
