Circuit board revision
Noelstan
Post by Noelstan »
I own an MK 3 from four years ago. How can I tell what version of the board I have and if it's old how do I upgrade it and the cost. Thanks Noel
Re: Circuit board revision
Little Dot MK III units from 4 years ago should be at minimum version 2.0 (it's printed in the PCB). There's really no reason to upgrade to a higher circuit revision as the changes are mainly QoL updates and will have minimal impact on the performance.
