Installing M8083 into Little Dot I+ V4.0
SirDigby
Post by SirDigby »
Hi there,
I am a bit confused with the manual, particularly this bit:
K1 and K2 set to the side of the “6JI” text.
I assume this means that the jumper occupies the two pins closest to the "6JI" text?
Also, I have an additional switch K3 so should I set all of them to the side of the 6JI text or take the jumper out of K3 completely?
I have placed a jumper over J1 and J2 and at the moment K1, K2 and K3 are all on the side of the 6JI text. I have put the tubes in. I get a faint orange glow and music is playing through them. I just want to clarify that I have done this correctly.
Why is K3 not mentioned in the manual?
Re: Installing M8083 into Little Dot I+ V4.0
The latest LD I+ Reference guide has been updated and can be found here: https://dl.dropboxusercontent.com/u/603 ... 0Guide.pdf
