rewiring transformer 110v to 220v for mkvi
mahdi8
Post by mahdi8 »
hi all,
does anyone know if its possible to rewire transformer from 110v to 220v? for little dot mkvi. i'm purchasing a used one and prefer to change the voltage rather than using a step up transformer. i've emailed david but havent got a reply yet
thanks
Re: rewiring transformer 110v to 220v for mkvi
It's not recommended you do yourself unless you are very experienced in working with electrical components. In any case, I have emailed you a diagram.
sdjksdafji
Post by sdjksdafji »
DavidZheZhe wrote:It's not recommended you do yourself unless you are very experienced in working with electrical components. In any case, I have emailed you a diagram.
Hi DavidZheZhe,
Could you send me a diagram as well ? I need to convert from 220v to 110v. Thanks.
Fpantalone
Post by Fpantalone »
Hi ... If not too much bother, can you please forward one to me as well? I'll have a qualified technician change it from 110 to 220. Thanks in advance
zhetanay
Post by zhetanay »
Please send me the conversion circuit of 110 volts in the "220 Volt
djedamrazuk
Post by djedamrazuk »
I would like to modify my Little Dot I+ from 110 to 220. Please send me the diagram. thanks
