* Changed thread topic *
So I "resurrected" my II+ and was thinking about using it as a preamp...
Would it be "safe" to use it with DC amps? I know that this issue arose with the MKII but I was wondering if this particular model suffers from the same issue.
May I also safely use this with a STAX SRM XH?
Little Dot II+ as preamp
Re: Little Dot II+ as preamp
Hi...I have a Little-Dot II+ and a Little-Dot II++ that I alternate between using as a pre-amp and they both work great. I have the output split and being fed into both of my amps.
The II++ is comparable to the MKII but a slightly older design. The The II+ (on the left) is similar also but is a DHT design using pentodes as power tubes instead of indirectly heated triodes.
turnkey assembly services
