Little Dot MKIII Power Tubes
MKCBrown93
Post by MKCBrown93 »
Greetings! I'm loving my new Little Dot MKIII!
Can I use: Sovtek 6H30Pi power tubes in my MKIII? I saw a YouTube video by AVITIO, wherein he installs these power tubes:
https://www.youtube.com/watch?v=7MeH9C4_Zi0
Then, I was reading: "Little Dot Tube Amps: Vacuum Tube Rolling Guide​" here:
https://www.head-fi.org/threads/little-dot-tube-amps-vacuum-tube-rolling-guide.563884/
In this guide, under power tubes, the author states: "...most current production Little Dot amps can only accept 6N6/6H6P power tubes with the exception of the MkIV which can accept the 6H30Pi."
Thus, I am wondering, can current MKIII amps use the 6H30Pi power tubes, or would they somehow ruin it?
Thank you!
Re: Little Dot MKIII Power Tubes
6H6PI and 6H30PI are fully compatible, You can use it directly on MK3.
