MK2 V3.0 Uneven volume in channels.
DRKreiger
Post by DRKreiger »
I have an LD MK2, with V3.0 board.
The issue i am having is the volumes is very uneven left to right at lower volumes.
Furthermore, I have a some random spots around 40% or so where distortion rears it's ugly head. But if i push past that it goes away.
Is this an inexpensive POT active up?
What is a good upgrade for the factory one?
TIA
capetownwatches
Re: MK2 V3.0 Uneven volume in channels.
Post by capetownwatches »
It may be inexpensive but it is good quality - try some switch cleaner directly into the pot.
ALPS-27 would be the next step up - it should fit (just) into the MKll chassis.
If not there are plenty others available.
capetownwatches, thanks for your advice,
Drkreiger, the model: ALPS 16 (A100K), it suitable with MK2.
