I have a little Dot MK IV SE that I have had for some time. It has stopped outputting sound on the right hand side either from headphones or using it as a preamp. I can get it to output to both right and left channels from the headphones if I pull the headphone plug out just a small amount but it plays both channels through both sides at the same time and output is low power (confirmed using output from computer). I have tried swapping the tubes out with the same results and all tubes are getting power. Any suggestions that don't involve shipping back for repair?
Thanks!
Wendell
Little Dot MK IV SE only outputting one side
Re: Little Dot MK IV SE only outputting one side
I should clarify that it actually outputs both channels to the left hand side all the time but will do both when the headphone jack is out slightly (which makes sense now that I think about it)
