Hello All,
After coming back from vacation my amplifier is no longer working correctly (amplifier went from daily use to not being plugged in for about 3.5 weeks). I receive no amplification any longer. As far as I can tell, it seems to be heating up the tubes properly, though they seem a little cooler than usual.
I have already swapped out the tubes for others that are known to be working and I have the same issue. I swapped both the power cable and outlet, but that did not change anything either. I have tried to take a look inside, and as far as I can tell none of the capacitors have popped (though I'm not 100% sure)
Any further suggestions for troubleshooting? Thanks in advance!
Mk III no amplification
