Hi
I have an old Little Dot 2++ purchased between 2006 and 2008.
Would it be possible to put in the "product section" information about this one, even if mentioning "DISCONTINUED" and specify the type of valves to be used so i can find replacements.
I got confused between 2++ and MKII, ending up purchasing the wrong valves (following tube rolling article on MK2...my mistake really) because the labels on my valves have disappeared and couldn't find info.
In any case, amp is still nice to listen to, got an nice upgrade after using it with Raspberry Pi + DAC Hat (instead of using it with a CD player).
Have a nice day
Little Dot 2++ Info / Valves?
You do not have the required permissions to view the files attached to this post.
Re: Little Dot 2++ Info / Valves?
The Little Dot II++ used CV131 driver tubes and 6C19 power tubes.
