Little Dot II+ help needed (headphone jack)
newbieforever
Post by newbieforever »
I have an old Little Dot ii+ that's been having issues with the headphone jack, I think. Won't work properly unless you "wiggle" the jack to get sound from both channels. I'm planning to have it replaced by a pro but would like to purchase the jack myself (to be sure I get a decent one). What type of jack does this particular unit use? Want to match the specifications with the replacement (unless any of you can recommend a better one). Thanks in advance for your time!
Here's my Little Dot for reference:
