Hi,
Just got the LD MK8 SE and I am really enjoying it even on its stock tubes with the HD800S.
Now I want to know what are compatible alternate tubes that I could use with it, does it work to all 9 pin driver tubes? how could you tell which one is compatible or not? Can anyone please enlighten me i really want to know.
TIA
List of compatible driver/preamp tubes for LD MK 8SE
Re: List of compatible driver/preamp tubes for LD MK 8SE
The MK 8 SE will use any 9-pin 12AT7 equivalents (ex. ECC802, ECC803, ECC833) for the driver tubes and 6H30 for the power tubes. The 6H30P-DR "super-tube" would be the ultimate power tube upgrade, but we really only recommend it as the final tweak in your system due to its high investment cost vs perceived benefit.
